i assume your erevo is a 1/10th same as mine
this pic shows battery size allowable
i assume you have a mamba monster, so you can go nuts with 6s
heres a list of lipos that fit
2S
2s Hyperion 5000mah 45C Soft
--Direct Fit
SPC 2s 5200 40C
SPC 2s 6000 30C
2s SMC 6000mah 28c
2s SMC 8000mAh/28C/7.4V Soft Case Lipo
2s SMC 9000mAh/28C/7.4V, Soft Case Lipo
2s Turnigy 30c 5000mah soft
--Minor Mod/Extend Batt Door Out
2S Turnigy 5200mAh 5.2 Hard Case
--Minor Mod/Trim Batt Door For Wires
2S Turnigy 5000mAh 5.0 Hard Case
2s Turnigy Nanotech 6000mah 25-50c
--Direct Fit. Need a few layers of duct tape on the top of the pack for a snug fit.
2S Sky Lipo 5000 mah 40C
--fit snugly
2s Nosram Fat Cobra hardcase
–direct fit
2s team orion carbon 7000 35c
--direct fit
2s Zippy FlightMax 5000mah/30c/hardcase
--Minor mod: remove both “L” brackets, take “L” bracket that was at the back of compartment, move screw to closest hole to corner of bracket and attach to where front “L” bracket was located. Distance should be PERFECT, nice and snug!
RC DUDE Power 5000mah/35c RCDude.com
--direct fit
HiCountryHobbies/Billowy Power 5200mah/50c HiCountryHobbies.com
--direct fit
3S
3s Hyperion 5000mah 45C Soft
--Direct Fit
3s Max Amps -6000xls
3s Team Orion Carbon 4700Mah 45C
3s Turnigy 30c 5000mah soft
--Minor Mod/Extend Battery Door Out
3s FlightMaxx 30c 5800mah
--minor mods required, enlarge hole on battery door
3s Turnigy Nanotech 6.0 6000mah 25-50c
--remove retainers & back out or trim screws if they extend into battery compartment.
3s zippy 30c 5000mah
3s SPC 5200 40C
--“tight fit, a little “work” needed” – 87GN
3s Kypom K6 6000mah
-- fits perfectly
3S SPC 5200 mAh 40 C
-- remove retainers & back out or trim screws if they extend into battery compartment.
RC DUDE Power 3s 5000mah/35c RCDude.com
--direct fit.. very snug 29mm tall
--direct fit.. snug 28mm tall
4S
4s Turnigy 4000mah 30C
--Minor Mod/Extend Battery Door Out (Same size as the Turnigy 3s 5000mah 30c soft)
erevo 1/10,14.4v dewalt , evx-2 with extra caps, Quad 1S lipo, ubuntu user, Youtube Channel - Thestinger30 ,Hyperion EOS0606i x2, Savox SB-2270SG, Hobbyking 150amp esc, 36x74 1900Kv brushless inrunner
