zt_38 said
Hi guys,
Just wondering which Tacon motor should i get for my slash 4x4. I want to give it more ompphh!!
I am currently looking at the below two motors:
http://www.hobbypartz.com/96m215-3674-1900kv-9t.html
http://www.hobbypartz.com/96m214-3674-2800kv-6t.html
There is a video of jang running the 1900kv motor which seems pretty powerful. Would that be fine on my slahs as wel (do i need to change the esc?) ?
If you guys do you mind letting me know, would it fine to run the above motor in the 1/10th summit as welL?
i cant say how well those 2 tacon motors are, but im using the 4800kv 4pole sensored mated to a hobbywing 120amp esc. ive had to dial the power back quite a bit for my local track. im confident i could run it on a 1/8th scale track if i ran 3s. no matter how hard ive ran this setup, the motor has never gotten over 135-140 and thats with no heatsink. ive used this setup for over a month and im very satisfied with tacon/hobbywing so far.
in my opinion, i would upgrade motor and esc at the same time...that should give you all the "ooomph" youll ever want. just dont forget the program card for the esc, youll probably end up turning the power down.
