Ultimate RC NetworkRC Sites & TopicsRC ForumsRC VideosRC Photo Galleries
Ultimate RC
Ultimate Tamiya
Ultimate Traxxas
Monster GT forum
Kyosho Monster Trucks
Mini Off-Roaders
Associated RC10T4 info
Beginning RC info
Toy-class RC Reviews
Unbelievable RC
Ultimate RC Home RC Forum RC Videos RC Photos RC Projects & others Miscellany
Not a Member Yet? You're Missing Out!
Sign up in minutes for a free URC Network account and you'll be able to post in over 100+ forum categories, search over a decade of archived topics, exchange private messages with other members, upload pictures to the RC photo galleries, and much more!
Already have an account?
Sign in below!
GUTSLAYER's Avatar
"trying too hard bro"
GUTSLAYER - 12.28.12, 11:23 am Post #131: | Reply With Quote
I see, the RPM tranny seems pretty nice, only problem is I can't heat my seat sink over that plastic.. also the have 1 degree or 4 degrees of toe in so i'm not exactly sure I've i can flip the arms around
I'm considering the HR tranny because of the look and lack of toe, but i'm very skeptical of the graphite mold, quite a few people have had cracks in it :/
Dr. Isotope's Avatar
"ALL THE NEUTRONS"
Dr. Isotope - 12.28.12, 1:17 pm Post #132: | Reply With Quote
The RPM comes with 0º and 3º, and with a little work, you could just run the arm carriers backward to keep factory anti squat.
There are no atheists in the foxholes / There is no intellect in the air / There are no scientists on the way down / Just a working example of faith versus physics. --El-P, Flyentology
GUTSLAYER's Avatar
GUTSLAYER - 12.29.12, 1:51 am Post #133: | Reply With Quote
does the standard traxxas 2wd gear box have that anti squat? if so i've literally never noticed
I know you can flip the arm carriers around to keep the antisquat, however the holes will no longer be M4 to M4, instead it's M3 to M4.. which I'm not concerned about drilling out, merely how that change in screw diameter will affect my chassis holes...
Edit: so I just walked outside to examine the stock case and it does have anti squat... So now that I've gone mid motor... My squat is.. Well, "prosquat"?? Lol! Or maybe just squatting? Haha anyways, how would you go about solving this issue?
Just wanna express my frustration with all of the little things that I had absolutely idea about until I went mid motor; my god the confusion! Haha, but I guess this is how you learn D:
(Last edited by GUTSLAYER : 12.29.12 at 2:02 am)
"ALL THE NEUTRONS"
Dr. Isotope - 12.29.12, 9:26 am Post #134: | Reply With Quote
I made a wedge that goes under the gearbox to reset the antisquat. Then I went to an FLM case which has no antisquat, and had to make a smaller wedge.
The RPM actually has 3.3mm on one side (so that the threads self-tap) while the other hole is 4mm, so the screw passes through. You would just use slightly longer screws with locknuts to hold the reversed arm carriers in place.
GUTSLAYER's Avatar
GUTSLAYER - 12.29.12, 10:50 am Post #135: | Reply With Quote
Clever on the wedge I was thinking of something along those lines to sit under the gearbox, I guess the RPM case will be the best gearbox for me since ill have minimum work to correct the anti squad since the arm carriers mount independently.
Appreciate the help as always dr. Isotope
GUTSLAYER's Avatar
GUTSLAYER - 12.30.12, 9:04 pm Post #136: | Reply With Quote
quick update on things:
ordered a full set of Fast Eddy metal shielded bearings and rubber sealed bearings for the axle carriers, since I've already blown through 3 or 4 of the cheap bearings I purchased off ebay :/ I would not advise the quantity over quality route lol
The RPM Gearbox was also purchased to correct my anitsquat issue and I'm worried that the custom gearbox I made may have warped and caused the teeth of fall out of sync
Additionally a Robinson Racing Xtra Hard Steel Idler gear was purchased to minimize on gear teeth wear.
An FLM sealed steel differential was also purchased to increase performance and prevent gear wear.
Lastly.. the impulse buy
A set of Gmade XD 85mm Piggy Back shocks was ordered since I am currently running Traxxas Ultra Shocks and... well why not
Pictures will be up when I receive the items (expedited shipping!)
trashyrich's Avatar
trashyrich - 12.31.12, 3:56 pm Post #137: | Reply With Quote
Been watching this build for some time. Nice job.
I hope you get all of the little stuff sorted out.
It is nice to be important, but it is more important to be nice.
B2Bad's Avatar
B2Bad - 12.31.12, 6:01 pm Post #138: | Reply With Quote
some day my slash might look half that good.
Traxxas Slash 2wd and traxxas stampede are currently the only two I have.
bigdodge44150 - 1.01.13, 9:34 am Post #139: | Reply With Quote
Just curious why the 85mm ?
GUTSLAYER's Avatar
GUTSLAYER - 1.01.13, 2:45 pm Post #140: | Reply With Quote
trashyrich: thanks a lot man, I really hope it all gets sorted out as well, i'm tired of seeing the slash sit on the work bench! it's been too long!
B2Bad: ha! and one day i'm sure it will! thanks man, means a lot. it's been in the works for over two years, it's taken quite some time to get this far, tons of mistakes and bad purchases / ideas along the way :P haha
bigdodge44150: well 85mm shocks are the proper slash 2wd front shock length.. right? lol you've got me second guessing myself now bigdodge! hahaha. On their site it says 85mm is the proper front shock, so I assume should be getting the right ones :P
http://www.amainhobbies.com/product_...FaN_QgodDkMAHg
Featuring: Ultimate Tamiya, Traxxas Slash forum, Slash 4x4 forum, Ultimate RC forums
Original content & design copyright ©2000 - 2013, Bamidele O. Shangobunmi & the Ultimate RC Network. Privacy policy
Lego fan? Check out JANG's LEGO blog and LEGO videos on YouTube
