JSchubz's Avatar
JSchubz - 1.08.13, 11:07 pm Post #1: | Reply With Quote
Long story short...
I got a used Losi XXX-NT with the Mach .15 engine. It was originally a pull/roto start (but missing pieces) so I made a new cover plate from 1/8" aluminum. I used a piece of silicone from a cupcake mold to make a gasket. I readjusted the pegs on my Starter Box to fire it up, but I only had the engine running (not driving) for 5-10 minutes (one of the clutch bearings is smoked). The gasket works, no leaks!
Will my DIY plate be ok? The other non PS cover plates I have seen are 'pushed in' the fill the void in the crankcase, while mine is just a cover...
Is there a reason the non PS plates are 'pushed in'? Better fuel distribution? (Just guessing)
One more question; How does the Mach .15 compare to an OS Max .15CV Hyper? (I have the OS, still new in the box....!)
Thanks from a ~Nitro-newby!
ChuckFinley's Avatar
ChuckFinley - 1.09.13, 9:11 am Post #2: | Reply With Quote
JSchubz said
Long story short...
Plates are pushed in to reduce crankcase volume. Too much volume will decrease performance, but if it works then great.
JSchubz's Avatar
JSchubz - 1.09.13, 10:54 am Post #3: | Reply With Quote
So I have found that a non PS cover plate from a .12 should work on my Mach.15?
A DYN6534. Can anyone confirm this?
Or would I be better off dropping in the OS engine?
What makes the .15 'Hyper', anyway? I guess just because it comes with the 10A slide carb? That it?
Thanks again
