nsticka - 1.22.17, 8:27 am Post #1: | Reply With Quote
under acceleration.
only thing changed was swapping out stock hinge pins on rear a arms to strc hinge pins with nut.
wheels, bearings, axles seem fine.
any other ideas or areas to trouble shoot?
Ofna-GTP2e speed runner
Losi-SCTE 1.0-drag/speed 2200kv/6s
TRX-Slash 4x4 8s capable speeder
TRX Rustler VXL-on hiatus currently.
TRX ERBE- 6s and 28/50 gearing; still in progress.
rcfnatic123's Avatar
rcfnatic123 - 1.22.17, 11:16 am Post #2: | Reply With Quote
Which slash you got, nitro or electric?
stevenator128's Avatar
"Inexperienced User"
stevenator128 - 1.22.17, 11:31 am Post #3: | Reply With Quote
Are there adjustable rear toe settings you might have changed by accident? Do the rear arms still move up and down freely?
Never been a fan of short coarse. I've always preferred short smooth.
nsticka - 1.22.17, 1:42 pm Post #4: | Reply With Quote
electric.
proline lcg chassis rpm'd out.
i did put on new strc rear hub carrier 1 degree toe in on right side.
cant get left rear hub carrier off as the hinge pin is stripped
rear a arms do move freely
thegrafxguy's Avatar
thegrafxguy - 1.22.17, 4:39 pm Post #5: | Reply With Quote
Isn't stock 1.5 degrees? Different toe on each side will definitely cause some weirdness.
RC8.2e Factory Team - RC Gear Shop 2150kv, HW XERun SCT Pro, Savox 1260 Servo
Sakura D4 AWD - Tacon 3930kv, HW EZRun 60a, Blue Bird Servo
Spektrum DX4S
JesterTheJoker's Avatar
"I-/"
JesterTheJoker - 1.23.17, 5:15 am Post #6: | Reply With Quote
as the grafxguy said. theres a .5 degree toe difference between them, theres your issue. Drill out that stripped hinge pin or get a pair of flat nosed locking pliers on it
True creativity has an element of madness, its what makes it un-predictable
-Aspiring Psychologist, Actor, and Backyard Mechanic-
nsticka - 1.23.17, 7:11 am Post #7: | Reply With Quote
I do not know as nothing mentioned on website.
nsticka - 1.23.17, 7:13 am Post #8: | Reply With Quote
im going to have to plus I bought the rear hub carriers that came with the kit.
this should do the trick.
nsticka - 1.30.17, 6:45 am Post #9: | Reply With Quote
all good now with replacing rear hub carriers.
thegrafxguy - 1.30.17, 6:46 am Post #10: | Reply With Quote
Glad it worked out
Spektrum DX4S
