draco321's Avatar
draco321 - 9.29.16, 12:18 pm Post #31: | Reply With Quote
Not on castle motors they can't take a lot before they get too hot. That would be true for stock rtr non castle motors because they are made out of cheaper materials which means it will heat up faster than castle motors
Losi 8t 2.0. Xray Rx8 Neu 1515 X-ray T3 1406 7700kv
On road Losi L8 1515
Losi DBXL Losi MTXL Hpi 5t 2028
Losi mini 8t 1415
vintage - 9.29.16, 2:35 pm Post #32: | Reply With Quote
Hope my earlier post didn't mislead you, as Draco said, that gearing is for low 30s. You should be able to gear that motor for at least the mid to high 40s without heat concerns on 3s, or much higher if you're going to keep the runs short and monitor temps.
draco321's Avatar
draco321 - 9.29.16, 3:40 pm Post #33: | Reply With Quote
In a 2wd stock slash you can run 30t pinion for speed and 19t for off-road why are you running a 14t with the Castle.
(Last edited by draco321 : 9.29.16 at 4:04 pm)
Losi mini 8t 1415
draco321's Avatar
draco321 - 9.29.16, 3:47 pm Post #34: | Reply With Quote
I almost forgot if you are not running the mamba max pro esc I would not run high gearing because the esc is gonna either get hot very quickly and thermal shutdown or fry it.
Losi mini 8t 1415
ser3100 - 9.29.16, 8:04 pm Post #35: | Reply With Quote
It was what castle recommended
ser3100 - 9.29.16, 8:05 pm Post #36: | Reply With Quote
And I thought the mamba could handle that power?
vintage - 9.30.16, 5:23 am Post #37: | Reply With Quote
The mamba max pro can handle the power easily, Draco is saying to be careful if you're using the sidewinder.
vintage - 9.30.16, 5:30 am Post #38: | Reply With Quote
It might be my fault. When I first heard he was going to run exclusively 3S I suggested he start with the lowest gearing that could fit to keep controllable and adjust up from their.
draco321's Avatar
draco321 - 9.30.16, 7:29 am Post #39: | Reply With Quote
The sidewinder esc will be fine on 3s if you install a cappack on the esc.
Losi mini 8t 1415
ser3100 - 9.30.16, 8:36 am Post #40: | Reply With Quote
Whats a cappack?
