draco321's Avatar
draco321 - 9.30.16, 10:50 am Post #41: | Reply With Quote
It's capacitors for the esc.
Losi 8t 2.0. 1518 Losi Muggy 1430
On road Losi based on the 8 platform 1515
Losi Ten T 1515. SCTE 1515
Losi mini 8t 2850
Traxxas Xmaxx 2028.
vintage - 9.30.16, 12:27 pm Post #42: | Reply With Quote
do you have the sidewinder or the mamba max pro?
ser3100 - 9.30.16, 1:01 pm Post #43: | Reply With Quote
mamba max pro sct.
ser3100 - 10.01.16, 10:04 am Post #44: | Reply With Quote
I think i found my problem. a loose slipper clutch. tightened it up yesterday and now it wont stop doing wheelies. Im going to gear down now that i found the issue.
cobycobie's Avatar
"Takin' the E to the Maxx"
cobycobie - 10.09.16, 10:29 am Post #45: | Reply With Quote
Might be a bit late for this, but gearing down will make it wheelie even more.
If at first you don't succeed; call it version 1.0.
smirk-racing's Avatar
smirk-racing - 10.09.16, 12:40 pm Post #46: | Reply With Quote
Turning UP the punch control value (which means more punch control, which means less change in speed per unit time) will help reduce wheelies.
vintage - 10.09.16, 4:34 pm Post #47: | Reply With Quote
With brushless and lipo, this tends to only be true if the motor is so over-geared that it's way too hot already. Otherwise the motor will produce so much power under load that it accelerates faster when geared for a higher top speed just because a given change in rpm results in a greater change in speed when geared for a higher top speed.
Gearing for a slower speed means a given rpm change results in a smaller speed change and thus fewer wheelies and more easily controlled acceleration.
cobycobie's Avatar
cobycobie - 10.09.16, 7:08 pm Post #48: | Reply With Quote
Good point.
G&B Mike - 10.24.16, 12:28 pm Post #49: | Reply With Quote
I've heard that upgrading a 2wd slash to the SCT castle brushless system and running 3s makes it nearly impossible to control. Anyone have any input on this?
llDemonll - 10.28.16, 8:12 am Post #50: | Reply With Quote
I'm on a 2S with stock gearing and a 3900kv motor and the thing is already quick as -[DISALLOWED -- edit your post]--[DISALLOWED -- edit your post]--[DISALLOWED -- edit your post]--[DISALLOWED -- edit your post]-. for a basher car, i wouldn't go any quicker personally. quick look says the castle is 3800kv and will be nearly identical. 3s will be effing fast
