nsticka - 1.22.17, 8:27 am Post #1: | Reply With Quote
under acceleration.
only thing changed was swapping out stock hinge pins on rear a arms to strc hinge pins with nut.
wheels, bearings, axles seem fine.
any other ideas or areas to trouble shoot?
Ofna-GTP2e speed runner
Losi-SCTE 1.0-drag/speed 2200kv/6s
TRX-Slash 4x4 8s capable speeder
TRX Rustler VXL-on hiatus currently.
TRX ERBE- 6s and 28/50 gearing; still in progress.
rcfnatic123's Avatar
rcfnatic123 - 1.22.17, 11:16 am Post #2: | Reply With Quote
Which slash you got, nitro or electric?
stevenator128's Avatar
"Inexperienced User"
stevenator128 - 1.22.17, 11:31 am Post #3: | Reply With Quote
Are there adjustable rear toe settings you might have changed by accident? Do the rear arms still move up and down freely?
One can lose things and one can loosen things. "Loose" is very rarely a verb; it is an adjective, and it describes the grasp some have on this concept.
nsticka - 1.22.17, 1:42 pm Post #4: | Reply With Quote
electric.
proline lcg chassis rpm'd out.
i did put on new strc rear hub carrier 1 degree toe in on right side.
cant get left rear hub carrier off as the hinge pin is stripped
rear a arms do move freely
thegrafxguy's Avatar
thegrafxguy - 1.22.17, 4:39 pm Post #5: | Reply With Quote
Isn't stock 1.5 degrees? Different toe on each side will definitely cause some weirdness.
Spektrum DX4S
"Certified Music Junkie"
JesterTheJoker - 1.23.17, 5:15 am Post #6: | Reply With Quote
as the grafxguy said. theres a .5 degree toe difference between them, theres your issue. Drill out that stripped hinge pin or get a pair of flat nosed locking pliers on it
nsticka - 1.23.17, 7:11 am Post #7: | Reply With Quote
I do not know as nothing mentioned on website.
nsticka - 1.23.17, 7:13 am Post #8: | Reply With Quote
im going to have to plus I bought the rear hub carriers that came with the kit.
this should do the trick.
nsticka - 1.30.17, 6:45 am Post #9: | Reply With Quote
all good now with replacing rear hub carriers.
thegrafxguy - 1.30.17, 6:46 am Post #10: | Reply With Quote
Glad it worked out
Spektrum DX4S
