robft's Avatar
robft - 3.27.17, 11:33 pm Post #1: | Reply With Quote
Hi Guys,
Finally got round to building up my slash 2wd but have hit a problem you might be able to help with.
Building the transmission and trying to push the top drive gear (3195) onto the input shaft, presumably it needs to push up flush to the pin but as you can see in the photo, it stops .5 cm before it even reaches it.
Am I missing something? All parts are new and traxxas.
thanks Rob
robft's Avatar
robft - 3.28.17, 12:58 am Post #2: | Reply With Quote
also, the idler gear (3696) is shown on the schematic, as having bearings and shims on each side but does not give a part number or ID for the cylindrical part that goes through it, any ideas?
thanks Rob
Rob5059 - 3.28.17, 3:56 am Post #3: | Reply With Quote
You need to press the gear on. Deep socket and a vise or hammer.
thebasher255's Avatar
"brushed motors are fast too"
thebasher255 - 3.28.17, 5:17 am Post #4: | Reply With Quote
I think the gear goes on the other side of the shaft, but still facing the same direction. And as far as I can remember, it does need to be press-fit with some decent force.
Smell something burning? Sorry, I was thinking.
robft's Avatar
robft - 3.28.17, 5:51 am Post #5: | Reply With Quote
ok, thank you. I contacted Modelsport (UK) and they suggested heating as another option. thankyou for your suggestion too, I will try them
thanks Rob
thebasher255 - 3.28.17, 6:00 am Post #6: | Reply With Quote
No worries, hope you get it worked out.
Also, I couldn't find any specs on the idler gear shaft either. Best I can tell it is included with the gearbox case, and cannot be purchased separately. That said, I know the od should be 5mm because the bearings are 5x11. Past that I don't really know.
robft's Avatar
robft - 3.28.17, 6:09 am Post #7: | Reply With Quote
thanks Basher, you right, modelsport said I had to buy the whole housing, I got the Hr one but have to buy the traxxas one anyway for that one part. I will give it a go in the am when my patience is restored, thanks again
thanks Rob
slick2500's Avatar
slick2500 - 3.28.17, 10:43 am Post #8: | Reply With Quote
See if anyone on eBay has that part?
Ecx 2wd Ruckus
Traxxas Stampede XL-5
Traxxas Summit 1/10
Team Associated Apex
Team Associated RC10B2
robft's Avatar
robft - 3.28.17, 11:51 am Post #9: | Reply With Quote
good idea Slick, found out that a hammer works, ebay is a good idea
thanks Rob
slick2500's Avatar
slick2500 - 3.28.17, 12:48 pm Post #10: | Reply With Quote
I did a quick search and found one for the Nitro Stampede/Rustler it looks different than the part you are looking for though.
Ecx 2wd Ruckus
Traxxas Summit 1/10
