SYRC's Avatar
SYRC - 12.03.12, 11:50 am Post #1: | Reply With Quote
got a hpi scream and want to put it in my slash- what do i need to do with the motor plate and what gear pinion will fit on the 5mm shaft??
also any tips i need to know about doing this? sort of thinking making it in to a truggy!
crusey_aus's Avatar
"These Pretzels !"
crusey_aus - 12.03.12, 1:23 pm Post #2: | Reply With Quote
What size is the motor ?
What ESC are you planning to use ?
What voltage do you plan to run (number of cells) ?
What speed do you want ?
Cheers
Slash Plati
num
Xerun 150, Tenshock SC401 (3500kv)
Gensace 5000mah 40c
Bhilly83's Avatar
"Jack of all things R/C"
Bhilly83 - 12.03.12, 1:36 pm Post #3: | Reply With Quote
all you need is a 5mm 32p pinon. I like novak and castle pinons, but Robinson Racing makes good ones as well called the absolute. the gears may also be called mod .8.
Nothing is needed to be done to the plate. If you have a center diff it needs to be replaced with the slipper and you need to run it very tight.
I am assuming you are going to run a 4s. If so you need the traxxas battery expansion kit. http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXUVZ8
With that you will be able to run a 4s battery or two 2s packs. I use that kit to run a single 2s 10000mah battery(same size as a 4s) and works great.
If your running a Mamba Monster esc or the hpi re-branded MM traxxas makes a Mamba Monster mount.
SYRC's Avatar
SYRC - 12.03.12, 2:13 pm Post #4: | Reply With Quote
the motor is here
http://www.hpiracing.co.uk/piw.php?partNo=101713
esc is here
http://www.hpiracing.co.uk/piw.php?partNo=101712
running 4s got the battery extension pack ready
so can you give me more info on the pinion and plate? any mods needed
SYRC's Avatar
SYRC - 12.03.12, 2:16 pm Post #5: | Reply With Quote
the motor is here
esc is here
so can you give me more info on the pinion and plate? any mods needed?
RCWiily's Avatar
RCWiily - 12.03.12, 2:45 pm Post #6: | Reply With Quote
No mods needed. The motor will bolt right to the stock plate. As stated above you will need a 5mm 32p pinion.
You can't understand cuz you're listening too slow.
Bhilly83's Avatar
Bhilly83 - 12.03.12, 7:16 pm Post #7: | Reply With Quote
Here is the esc mounting plate. The esc you posted is just a re-branded mamba monster. http://www3.towerhobbies.com/cgi-bin...?&I=LXXFD3&P=7
As far as the motor plate and mount the stock one will work without any mods. But you may want to upgrade the motor mount to one like this. http://www.amainhobbies.com/product_...ount-w-Bearing
it has a larger bearing for cooler running.
As far as pinons here is a list for you, its not complete. http://www3.towerhobbies.com/cgi-bin...5MM+&search=Go
I would use a pinon of 14-16t to start with.
SYRC's Avatar
SYRC - 12.04.12, 3:13 am Post #8: | Reply With Quote
thanks guys thats seems right!! yay!!
so any tips for doing this mods to watch out for?
running bashing etc?
ill be putting these wheels tires on? will they be ok?>>>>
http://www.modelsport.co.uk/absima-1...roducts/369632
moshiman's Avatar
"I'll fix it later..."
moshiman - 12.04.12, 4:04 am Post #9: | Reply With Quote
Your driveshafts will turn to butter with that much power. Pick up some teknos or mips at least for the rear.
Losi 8ight-t tekno converted, Durango DEX408, Duratrax DXR-8E, Losi SCTE, Slash 4x4, Tamiya TT-02
Daedlux - 12.04.12, 6:44 am Post #10: | Reply With Quote
It's not necessarily a must ,but The REVO slipper clutch upgrade really helps keep the clutch cooler with all that added power. The fiber ones tend to burn up.
Quote
17mm ftw
