STIGCRAFTER's Avatar
"Eat, Sleep, Lego, RC, Youtube,"
STIGCRAFTER - 7.22.16, 12:37 am Post #31: | Reply With Quote
^^^ I kinda hope someone does that, too. In fact if I or someone else really wanted to, they could even make one on a 3D printer, in theory. But for now I'd rather just cut existing pieces, rather than make my own.
"Bambidexterous: When you can skin a deer with both hands" - Mike Falzone
Instagram: @stigcrafter Youtube: STIGCRAFTER
fyrstormer - 7.22.16, 11:27 am Post #32: | Reply With Quote
Oh, definitely. Much easier than trying to make a new one from scratch.
Squeegie's Avatar
Squeegie - 7.22.16, 11:57 am Post #33: | Reply With Quote
If you use JB Weld, make sure you get the one's made for Plastic:
http://www.jbweld.com/collections/plastic-composite-pvc
Velineon's Avatar
"Semi-Vacationing User"
Velineon - 7.22.16, 1:12 pm Post #34: | Reply With Quote
Get the PlasticWeld syringe
RCs Owned: Traxxas Slash 4x4 - Muscle Slash, Axial Exo-Terra Buggy, Tamiya TT-02 - 73 Carrera RS/85 AE86 Trueno Coupe
Quote
"If it ain't broke, fix it till it is."
Quote
people who use pnvv quotes in their sig are dorky sheeple
STIGCRAFTER - 12.12.16, 1:33 am Post #35: | Reply With Quote
Iím expecting some parts for the summit diff to arrive soon, so I thought itís a good time for me to give an overdue update.
Firstly, Iíve started over with a new Slash diff case (which was my backup one incase this doesnít work, so I hope this works) to allow me to keep more of Slash case intact, including the top of the case which means I donít have to find a convoluted way to attach the shock tower and screw the two halves together.
So far I have mainly modified the front half, and as you can see I have cut out a lot of it, but not as much as before. To compensate for this, Iíve had to cut out a lot more of the Summit diff.
On the back half of the diff case I have widened the hole for the bearing (using a Dremel!) to allow the slightly bigger bearing on the left side of the Summit diff (which is the same size as the bearing on the right side of the Slash diff) to fit, allowing me to attach the finished front half to the rear case and shock tower.
Speaking of shock tower, Iíve had to take out some of it as well to allow space for the locking arm thing. Hopefully later Iíll be able to strengthen whatís left so it doesnít fall apart.
(Last edited by STIGCRAFTER : 12.12.16 at 1:37 am)
fyrstormer - 12.12.16, 1:46 am Post #36: | Reply With Quote
Those are very rough cuts. What tools did you use?
STIGCRAFTER - 12.12.16, 1:41 pm Post #37: | Reply With Quote
I mainly used a stanley knife and small tin snips, and occasionally a wire cutter. They're not the best tools, but I found them the easiest to use and get access to.
fyrstormer - 12.12.16, 2:57 pm Post #38: | Reply With Quote
Maybe use an aluminum shock tower since you have to cut away part of it.
STIGCRAFTER - 12.12.16, 4:22 pm Post #39: | Reply With Quote
^^^ Probably a good idea. Any suggestions on which one to get?
fyrstormer - 12.12.16, 4:29 pm Post #40: | Reply With Quote
Traxxas has one, and STRC has one also. I've never been disappointed with STRC's aluminum.
However, I just noticed JConcepts has a carbon-fiber shock tower, and that might work even better because it's thin and flat. http://www.jconcepts.net/shop/traxxa...conversion-kit
