roadhog29389 - 10.20.16, 3:32 am Post #1: | Reply With Quote
I have recently been looking for a stampede 4x4 or telluride to turn into a racer, Along the lines of Jang's Shapeshifter. I've come across a guy selling the latter for a good price but am wondering if I can put the longer stampede arms on a telluride? I know there's a lot of shared stuff across the platforms but am unsure of what works and what doesn't.
fyrstormer - 10.20.16, 7:11 am Post #2: | Reply With Quote
Everything is interchangeable. The Telluride is a 4Pede with narrower A-arms, short-course tires, and different body posts. (I recommend keeping the Telluride body posts unless you need the 4Pede posts to fit a pre-cut body.)
roadhog29389 - 10.20.16, 7:24 am Post #3: | Reply With Quote
Cool, All I needed to know. Body posts will stay as just from images I can tell they're better than the Stampede. I may change the clutch at some point but I don't really stuff about with fine tuning them so it'll probably be just fine as is
fyrstormer - 10.20.16, 12:37 pm Post #4: | Reply With Quote
I have the 4Pede clutch in both of my Tellurides, and the Slash center diff in my 4Pede. I think the center diff is a great upgrade, it really improves the handling at high speed.
lsear2905's Avatar
"Hasa Diga Eebowai!"
lsear2905 - 10.20.16, 3:27 pm Post #5: | Reply With Quote
Like a buggy? If you plan on racing, go for a Slash 4x4 with the longer chassis.
Also, as previously stated - get a centre diff, and sway bars too.
from Melbourne, Australia (where Winter is Summer, and we use the metric system)
Bored? Check out and follow my Instagram feed @mycousinscrogg
Really bored? lsear2905's Garage in the General RC section
Want even more? Check out my flickr page at flickr.com/lsear
roadhog29389 - 10.21.16, 11:42 pm Post #6: | Reply With Quote
Since you seem to know your stuff, Do you know if the Telluride uses bushings anywhere in it?
fyrstormer - 10.23.16, 10:52 pm Post #7: | Reply With Quote
Plastic bushings in the steering bellcranks. You can replace them with 5x8x2.5mm bearings, but if you do, I recommend using stainless-steel bearings because the top bearings are impossible to clean without removing the front skidplate, and they will rust otherwise. Also, it requires a VERY firm hand to keep the servo-saver spring held in-place while you're replacing the bushings with bearings. You'll see what I mean when you get in there; the spring retainer is ultimately locked in-place by the upper bearing on the bellcrank. You may want to use a box-end wrench or something similar to press hard on the spring retainer while you're fitting the bearing into place.
roadhog29389 - 10.24.16, 3:29 am Post #8: | Reply With Quote
OK, I'll keep that in mind. I have had to put servo savers together before and resorted to a vice and pliers to twist the top on
fyrstormer - 10.24.16, 10:42 am Post #9: | Reply With Quote
It doesn't twist together, it presses together. You'll see what I mean.
roadhog29389 - 10.27.16, 5:15 am Post #10: | Reply With Quote
It has arrived!
