Not a Member Yet? You're Missing Out!
Sign up in minutes for a free URC Network account and you'll be able to post in over 100+ forum categories, search over a decade of archived topics, exchange private messages with other members, upload pictures to the RC photo galleries, and much more!
Already have an account?
Sign in below!
Ian517's Avatar
Ian517 - 1.01.13, 7:50 am Post #1: | Reply With Quote
Does anyone have experience with the high-torque HS-7975HB or the high-speed HS-7966HB? They specify extremely fast speeds of .14 seconds and .10 seconds on 4.8 volts respectively.
These servos are about the same price ($45-ish, Tower Hobbies) as the seemingly popular HS-5645MG/HS-5625MG "toque" and "speed" servos. Their specified transit times are .23 and .17 respectively, on 4.8v.
I'm guessing metal gears are stronger than Karbonite gears... whatever Karbonite is... but does anyone here have a word against the faster Karbonite servos? I'm looking for a servo to go into a Rustler and then possibly into a Slash 4x4 at a later date. Gotta love those Tower Hobbies "we miss you" 25-off-50 coupons!
(Last edited by Ian517 : 1.04.13 at 5:46 am)
blog.ianjefferys.com
jimbo74's Avatar
jimbo74 - 1.03.13, 10:10 pm Post #2: | Reply With Quote
the karbonites aren't metal, but they are supposed to be a lot better than stock.... i have a karbonite geared servo in my rc18t, and i bash the heck out of it... haven't had any problems
"THE BITTERNESS OF POOR QUALITY REMAINS LONG AFTER THE SWEETNESS OF LOW PRICE IS FORGOTTEN"
JayhawkNavy02's Avatar
JayhawkNavy02 - 1.09.13, 5:05 am Post #3: | Reply With Quote
I have the HS-7975HB. Go with that for 2WD SCT or your Rustler, etc. About 150 oz of torque, .10 time, its perfect for 2WD. The other is a little low on torque and high on speed. Your voltage is wrong though, to get 144 oz torque and the .10 sec time you have to run it at 6.0 v vice 4.8 v however.
Control System: +Pulse Width Control 1500usec Neutral
Required Pulse: 4.8-6.0 Volt Peak to Peak Square Wave
Operating Voltage Range:
4.8-6.0 Volts
Operating Temperature Range: -
20 to +60 C (-4F to +140F)
Operating Speed (4.8V): 0.13sec/60 at no load
Operating Speed (6.0V): 0.10sec/60 at no load
Stall Torque (4.8V): 119oz/in. (8.6kg.cm)
Stall Torque (6.0V): 144oz/in. (10.4kg.cm)
Operating Angle: 45 Deg. one side pulse traveling 400usec
360 Modifiable: Yes
Direction: Clockwise/Pulse Traveling 1500 to 1900usec
Idle Current Drain (4.8V): 3mA at stop
Idle Current Drain (6.0V): 3mA at stop
Current Drain (4.8V): 200
mA/idle and 2.0 amps at lock/stall
Current Drain (6.0V): 240mA/idle and 3.0 amps at lock/stall
Dead Band Width: 2usec
Motor Type: Coreless Carbon Brush
Potentiometer Drive: 6 SliderIndirect Drive
Bearing Type: Dual Ball Bearing MR106
Gear Type: Karbonite Geas
Connector Wire Length: 7" (178mm)
Dimensions: 1.57" x 0.78"x 1.45" (40 x 20 x 37mm)
Weight: 1.87oz (53g)
For 4WD I prefer more torque to get all the wheels around in my SCTE, granted it's a heavier truck. Also if your receiver can handle 7.4V, I know the Futaba FASST can, it means that you can run the servo directly from your 2S lipo.
HS-7945TH Multipurpose Ultra Premium High Voltage Digital Servo
http://www.hitecrcd.com/photo.php?pi=887&size=four
Motor Type:7.4v
Wind Coreless
Bearing Type Ball Bearing
Speed (6.0V/7.4V):0.12 / 0.10 second @ 60
Torque oz./in. (6.0V/7.4V):250 / 319
Size in Inches:1.57 x 0.79 x 1.50
Weight oz.:2.40
(Last edited by JayhawkNavy02 : 1.09.13 at 5:11 am)
Team Associated RC8.2e, Losi TEN-SCTE, Pro-Line Pro-2 2WD SCT, Axial SCX10 Dingo, Traxxas Slash 4x4 VXL, Traxxas Stampede 4x4 VXL Truggy, Traxxas Mini-Summit VXL 4x4
Ian517's Avatar
Ian517 - 1.12.13, 5:47 am Post #4: | Reply With Quote
Thanks for the input! That 7945TH looks great, but it's way more money than what I'm looking to spend. Under $50, I've been choosing between the 7975HB and the 5645MG. The 7975HB's specs look better, but my concern is durability. You haven't had any issues in land vehicles with the 7975HB being non-metal? I figure going digital is a worthy step up from the 645MG? I'm looking to have fun getting around a track, but don't expect to get into hardcore competition.
Featuring: Ultimate Tamiya, Traxxas Slash forum, Slash 4x4 forum, Ultimate RC forums
Original content & design copyright ©2000 - 2013, Bamidele O. Shangobunmi & the Ultimate RC Network. Privacy policy
Lego fan? Check out JANG's LEGO blog and LEGO videos on YouTube
