Sign up in minutes for a free URC Network account and you'll be able to post in 100+ forums on 7 RC sites, search 8+ years of topics, buy & sell in the RC Flea Market, exchange private messages with other members, upload pictures to the RC photo galleries, and much more!
TheJANG's Avatar
"Indeed."
TheJANG - 10.15.09, 10:36 pm Post #1: | Reply With Quote
Since I'm unable to test the Desert Gator tomorrow due to a flooded track, I decided to pick up a quick & easy build to be my second test subject for the week. Even comes with a finished body in this re-release edition! Score!
► Subscribe to Ultimate RC Videos on YouTube!
► Tell a friend or family member about BeginningRC.com!
TheJANG's Avatar
"Indeed."
TheJANG - 10.16.09, 2:44 am Post #2: | Reply With Quote
The Group C chassis cars feature a build order that's not too common among Tamiya kits. Step 1 is to mount the tires, and step 2 is to set up the servo horn.
Picture 1: Be sure to carefully plan the placement of those adhesive strips before applying them to the wheels. The front wheels are wider than the tires and foams don't stretch, so I don't recommend putting the inside strips all the way out at the edges of the wheels, or they'll be left with adhesive exposed to the air to just collect dust & fuzz.
Picture 3: Here's the rigid front end setup with the typical pan car style floating kingpins. No big surprises here, as long as you center the kingpins properly in the knuckles.
Picture 4: Four super-long 4mm bolts attach the forward chassis brace and clamp the front clip onto the main chassis tub.
Tips:
Because this is the second Group C chassis I've done for Ultimate Tamiya, just refer back to my F40 build for tips. Also, as always, use threadlock on all set screws.
ID:	16821  Click image for larger version
ID:	16822  Click image for larger version
ID:	16823  Click image for larger version
(Last edited by TheJANG : 10.16.09 at 3:12 am)
TheJANG's Avatar
"Indeed."
TheJANG - 10.16.09, 2:54 am Post #3: | Reply With Quote
Picture 1: Four straight sides do a box form. This is essentially the rear chassis pod, with the wing strut mount attached to the back.
Picture 2: All mounted up with that sweet black-anodized motor that should propel this ultralight chassis quite nicely. The axle runs on just two bearings, and thankfully actual ball bearings are included here, though bushings are used elsewhere.
Picture 3: The diff uses just six balls and they're easy to insert, and the thrust bearing assembly goes into the outside hole on the hub. The thrust bearing is a preassembled unit, so finishing this whole unit off is a very simple and straightforward task. Just be sure to lubricate the business sides of the large pressure rings (unclear in the instructions).
Picture 4: I LOVE it when an onroader comes with an actual wing stay assembly! It's actually a lot more flexible than it looks.
ID:	16825  Click image for larger version
ID:	16826  Click image for larger version
ID:	16827  Click image for larger version
TheJANG's Avatar
"Indeed."
TheJANG - 10.16.09, 2:57 am Post #4: | Reply With Quote
There you have it! All done except for the electronics, which I'll drop in tomorrow. I only wish I could cheaply buy up a bunch of these bodies, unpainted, to use on future projects!
ID:	16829  Click image for larger version
ID:	16830  Click image for larger version
loco_oso's Avatar
loco_oso - 10.16.09, 5:23 am Post #5: | Reply With Quote
Looks great!
Traxxas Rustler and Mini E-Revo, AE RC10T, Kyosho Mini-Z F1, Tamiya M03L
locoososstuff.blogspot.com
TheJANG's Avatar
"Indeed."
TheJANG - 10.16.09, 11:33 pm Post #6: | Reply With Quote
Drove it today and I really like it! The Gr.C F40 I only drove on asphalt and it was good, but this one I ran on carpet and it had great traction and controllability. Video to come!
Zerohax369 - 10.17.09, 12:53 pm Post #7: | Reply With Quote
So is that smaller than a 1/10 and how tunable is it? What electronics are you using in it? That's one thing I love about Tamiya, how realist everything is. It looks really fun to drive around too.
Ray
TheJANG's Avatar
"Indeed."
TheJANG - 10.17.09, 1:09 pm Post #8: | Reply With Quote
It would be classified as 1/10th, but it's actually very very close to scale and thus larger than most 1/10th electric street RCs (which are smaller than 1/10th scale). It's 205mm wide, 19" long. It's not a proper racing chassis so it's not exceedingly tuneable, but you can change:
  • Pinion
  • Monoshock oil & spring
  • T-bar bushing (not sure exactly how that works other than fine-tuning CoG, but the manual suggests it's for oversteer/understeer)
  • Front springs
  • Front toe
The ball diff doesn't seem to be designed to be tuneable, though I think you could do it with fine shims and/or thicker lube.
For electronics I just threw in whatever was handy & available, this time my trusty DTX Intellispeed 8T Pro, and an Airtronics FHSS rx.
Adidas's Avatar
"Somebody's Watching Me"
Adidas - 10.17.09, 1:29 pm Post #9: | Reply With Quote
Wow, this is the car that my neighbor offered to me for 80$! Not the re- release, the original. Body and everything, even... I think a MSC buried underneath a bunch of random maybe R/C related stuff. I thought about buying it, but I'm not one to limit an R/C to a mere shelf.
RC10B4 Micro Citabria Bolink Econo-Rail
RC18R MCX
Rustler Slash 4X4
Micro-T Savage 25
Micro crawler Team Losi GTX
TheJANG's Avatar
"Indeed."
TheJANG - 10.17.09, 1:29 pm Post #10: | Reply With Quote
Thrust bearing is locked down on the outside of the right wheel hub, not against the diff itself. The wheel hub is then locked down against what's effectively the axle. It's set in such a way that you get a fixed amount of pressure against the plates, and the gear is actually slightly free-floating over the balls. You literally can't tighten it further.
(Last edited by TheJANG : 10.17.09 at 1:30 pm) Reason: spelling
Original content & design copyright ©2000 - 2010, Bamidele O. Shangobunmi & the Ultimate RC Network.
Current features: RC videos, Ultimate Tamiya, Traxxas Slash forum, Slash 4x4 forum, Ultimate RC forums, Air Hogs Sharp Shooter, Traxxas Titan, Traxxas brushless boat 6S, Axial XR10, Axial MOA
Lego fan? Check out Zeyek's Bionicle: Untold, Bionicle Untold: Behind the Scenes, and JANG's Lego Hero Factory MOCs
