RacerRC said
I think they where thinking lower center of gravity when they designed this crawler. The body I'm not too crazy about I think they could have done a better job with it. Looks like they are also using dual motors. I like the tranny based single motor 4WD system better then the two motor set up.
For scalers sure, for comp crawling there are things a moa can do, that even the best tuned shafty's can not. Example being massive under hangs on vertical climbs.
I have a local spot I go to that has a few lines that I can not get up with my FF-4 (ax10 axled rig), an LCC, and several other acx10 based rigs, but I can get right up it with any Berg or Bully I drive.
The body is functionally hideous. I do not like the looks much, but it sure looks like it will work great! No more having to run a bug body to be able to get back on wheels with out the 5 pt roll over penalty or 10 pt reposition.
Run it, break it, fix it, love it :]=~
