Gimpdiggity's Avatar
"Valiant Poultry"
Gimpdiggity - 8.03.11, 6:38 pm Post #1: | Reply With Quote
Hey guys.
The rear end of CircuitONE is sagging a bit more than I would like. It has 40wt oil in the shocks all around, but I think that the fact that the motor/ESC/heat sink all weigh a bit more than the stock stuff is just weighing it down a bit.
Just wondering, would stiffer springs be the solution to deal with this issue??
Thanks.
Bryton Starr's Avatar
"I'm An Experienced User! Woot!"
Bryton Starr - 8.03.11, 6:51 pm Post #2: | Reply With Quote
Stiffer springs would help. You could also add heavier oil or spacers.
Horsepower is how fast you hit the wall
Torque is how far you take the wall with you
"Valiant Poultry"
Gimpdiggity - 8.03.11, 7:01 pm Post #3: | Reply With Quote
Would the stiffer springs actually function better than spacers??
I understand how spacers work, I'm just wondering if there is any "down side" to using them as opposed to just a different set of springs.
indy34096's Avatar
"Do you even race?"
indy34096 - 8.03.11, 7:04 pm Post #4: | Reply With Quote
i guess use the spacers first and see how you like it, and if its not enough, then get a stiffer spring.
the stock springs are quite stiff though. i also have 40wt oil in my rears.
Bryton Starr - 8.03.11, 7:06 pm Post #5: | Reply With Quote
As far as I know there are no downsides to spacers. I have used them for a long time on my Rustler and haven't found any problems.
indy34096's Avatar
"Do you even race?"
indy34096 - 8.03.11, 7:07 pm Post #6: | Reply With Quote
i have 2mm of preload on my rears right now on my circuit. its brought up the rear end after an impact nicely.
"Valiant Poultry"
Gimpdiggity - 8.03.11, 7:09 pm Post #7: | Reply With Quote
What did you use for spacers Indy??
I guess before I mess with springs, I should probably make sure I haven't somehow lost some of the oil in the shock. I have never noticed any leaking, so I'm sure I haven't...but best to check I suppose.
indy34096's Avatar
"Do you even race?"
indy34096 - 8.03.11, 7:12 pm Post #8: | Reply With Quote
oh sorry i have the traxxas ultras in the back, and because i have both slashes i have an amazing amount of preload spacers laying around. they wont fit onto the stock shocks because the bore of the ultras is bigger than the electrix shocks.
"Valiant Poultry"
Gimpdiggity - 8.03.11, 7:19 pm Post #9: | Reply With Quote
Oh, okay.
I can probably find something that could make it work...I've read about people using fuel tubing as spacers. That could work and wouldn't cost much at all.
indy34096's Avatar
"Do you even race?"
indy34096 - 8.03.11, 7:21 pm Post #10: | Reply With Quote
you could do that no problem. or if you could find some huge zip ties as well.
