kriswithak57's Avatar
kriswithak57 - 1.01.13, 2:48 pm Post #321: | Reply With Quote
Hello all.Just wanted to chime in and say thanks for the forum. It's new years day and I got my torment for my 55th birthday on dec. 8th. I've spent the last 3 hours reading all 320 posts. Now I don't have any unanswered questions.lol
I have already switched my esc to a traxxes xl5 wp, installed the ecx aluminum shocks front and rear, and put in a dynamite 15T. This is the most fun I've had in a hobbie bar none. looking forward to continuing on with everyones help. Thanks again. Kris in Nova Scotia.
kriswithak57 - 1.01.13, 6:20 pm Post #322: | Reply With Quote
tweaker09 said
kdillon I put traxxas 3643 on the fronts and 5539 on the rear others may fit as well but that is what they had in stock at the hobby shop when I was there. You will need some longer screws to fasten them though.
I have the Traxxes 3643, and found they are about 3/8" to long compared to the plastic stock links. How did you make them work?
Gimpdiggity's Avatar
"Valiant Poultry"
Gimpdiggity - 1.02.13, 2:51 am Post #323: | Reply With Quote
Hi Kris, welcome to the forum.
With your links that are a bit too long, here is a stupid question that I'm you have already tried...but did you try turning the ends of them to "tighten" them?? That shortens them a little bit.
If you have already done that, have you looked at the parts where the links connect to the truck?? They have a couple of different mounting points.
They are circled in red on this image...one on the shock tower and the other on the hub.
If you are only a little bit off, you can use those other mounting holes to get them mounted. If I remember correctly, the Associated links that I used were a tiny bit longer than the stock parts as well. Mounting them in those extra holes did the trick just fine.
tow213 - 1.02.13, 5:59 am Post #324: | Reply With Quote
Hey Kris
Happy new year old what pinion gear you running I run the same system and us a 16 tooth keeps temp around 150 to 160 its a good system just watch the temps I race mine and its a rocket have fun
Rob in Winnipeg
kriswithak57 - 1.02.13, 7:48 am Post #325: | Reply With Quote
Thanks alot I really should have concidered the option holes that makes the difference. You guys are awesome.
kriswithak57 - 1.02.13, 7:52 am Post #326: | Reply With Quote
Also I'm using the 19t pinion that came with the motor. Not going to make any changes there until I go bl with LiPo.
tow213 - 1.02.13, 5:22 pm Post #327: | Reply With Quote
Just keep an eye on your temps try not to let it go above 155 should be fine
1
svtfmook - 1.23.13, 8:06 am Post #328: | Reply With Quote
is there a roll cage for the torment? or at least something easily adapted without modifying?
"Valiant Poultry"
Gimpdiggity - 1.23.13, 3:40 pm Post #329: | Reply With Quote
Probably not.
tow213 - 1.24.13, 10:40 am Post #330: | Reply With Quote
I haven't heard of anything yet
