@ Tacoman, naw, I'm working on the sway bars, the rear will eventually be made of aluminum rod, bent into shape, and using turnbuckles at the ends, these are mockups, but with the softer springs up front, I'm making a better bracket that will make it work much better, only does a little now, but soon it will work really well up front, and with the proper back mounts and all, it will work well.
@ Erevo, no offense taken, I have a 19 tooth and a 28 tooth pinion, but the set screws I have bought(lost the only one I had) use a size smaller than 1/16 or 1.5mm for the hex, I probably will never install the On/Off switch, LOL, but hopefully a new radio, a flysky, but depends on what's in stock, after I earn some more $moo-lah$ I am fine with my metal battery plate, thank you, but yeah, much to do so I can beat my friend's box-stock slash 4X4 by a lot!!!
