no one has even talked about the launch control. its says on the ad that you set the launch control for track conditions.its like on a real drag car they have a trans brake and the rpms are held at a certain level wich preloads the suspension and the trans brake is released when the light turns green this with massive high traction tires causes nearly instant acceleration , so you know traxxas will put a big tourqey motor in this thing and with the launch control and big rear tires it will probably be crazy fast of the line , and hard to control, so you have many things to make it fun and competitive launch control,suspension tune,tires,reaction time,throttle control,then you get in to your spur and pinion gear ratios then trans gear ratios,then weight mods and so on , if i had some one to run with i would get two and the timing system, ill still probably get one if it turns out good.
stampede 4x4, scx10 trail honcho, scx10 jeep cherokee,B4 buggy, savage ss flux, wraith,slash roller, wr8 abu dhabi flux. will work for tires !!
