imabeast's Avatar
imabeast - 4.23.12, 10:41 pm Post #1: | Reply With Quote
i have the torment my car can un bided how do i bind it again
plz help
wow nice that would have hurt alot more if i had feelings
crusey_aus's Avatar
"These Pretzels !"
crusey_aus - 4.23.12, 10:43 pm Post #2: | Reply With Quote
Plug bind plug into receiver bind port
Apply power to receiver
Select bind on your transmitter
Press button to bind
Remove bind plug from receiver
Cheers
Slash Plati
num
Xerun 150, Tenshock SC401 (3500kv)
Gensace 5000mah 40c
Gimpdiggity's Avatar
"Valiant Poultry"
Gimpdiggity - 4.23.12, 10:47 pm Post #3: | Reply With Quote
Here, let me look in the manual for you.
Page 6 Of The Manual That Came With Your Truck said
Binding
Binding is the process of linking the transmitter to a receiver. The DX2E and SR200 are bound at the factory. If you need to rebind, follow the instructions below.
1. With the receiver off, insert the bind plug into the BIND port on the receiver.
2. Power the receiver through any other port. The orange LED will flash continuously, indicating the receiver is in bind mode.
3. With the steering wheel and throttle trigger in the failsafe positions, normally full brakes and straight steering (see the Failsafe section on this page for more information), press and hold the bind button and turn on the transmitter. The green LED on the front of the transmitter will flash within three seconds, indicating the transmitter is in bind mode.
4. Release the bind button when the green LED flashes. Continue to hold the steering wheel and throttle trigger in the failsafe positions until the LED on the receiver glows solid.
5. The LED on the receiver will glow solid when the transmitter and receiver are bound.
6. Remove the bind plug and store it in a convenient place. You must rebind when:
Different failsafe positions are desired e.g., when throttle or steering reversing has been changed.
Changing receiver types e.g., changing from a DSM receiver to a DSM2 or Marine receiver.
Binding the receiver to a different transmitter.
Some Spektrum receivers, like the SR3001, use a bind button rather than a bind plug. The binding process is the same with this receiver, however, instead of inserting the plug before powering up the receiver, press and hold the bind button while powering up the receiver to enter bind mode.
imabeast's Avatar
imabeast - 4.23.12, 10:49 pm Post #4: | Reply With Quote
can u explaiun that better
"Valiant Poultry"
Gimpdiggity - 4.23.12, 10:51 pm Post #5: | Reply With Quote
You have the information taken directly from the manual. How much better can it get?
imabeast's Avatar
imabeast - 4.23.12, 10:56 pm Post #6: | Reply With Quote
uggh not working\
crusey_aus's Avatar
"These Pretzels !"
crusey_aus - 4.24.12, 12:10 am Post #7: | Reply With Quote
Whats not working ?
What transmitter and receiver are you using ?
Its a fairly simple process
Cheers
Slash Plati
num
Gensace 5000mah 40c
imabeast's Avatar
imabeast - 4.24.12, 2:41 am Post #8: | Reply With Quote
stock one
crusey_aus's Avatar
"These Pretzels !"
crusey_aus - 4.24.12, 3:22 am Post #9: | Reply With Quote
Stock what ?
Your thread title says Spektrum
Which Spektrum transmitter and receiver do you have ?
Cheers
Slash Plati
num
Gensace 5000mah 40c
imabeast's Avatar
imabeast - 4.24.12, 4:22 am Post #10: | Reply With Quote
the ecx torment stock dx2e and sr200
