joel12's Avatar
joel12 - 8.20.12, 8:24 am Post #1: | Reply With Quote
Lately my first sv2 esc would always stop and the red and yellow light start blinking every 5 minutes.
Then the esc burnt when the lights never came on.(was on 2s lipo)
2 weeks later I got my new sv2 esc and the lights never came on and 12-15 minutes later the green/yellow lights came on.
What does this mean?
Castle creations sv2 esc+7700kv motor+2s 3000mah 25c lipo=
50+ mph speed runs!!!!!!!!!!!!!!!!!!!!!
Evil genius jr.'s Avatar
Evil genius jr. - 8.20.12, 8:25 am Post #2: | Reply With Quote
13. What do the flashing LEDs mean? The LEDs can have different meanings depending on what you are doing.
If you are not calibrating and have no throttle input:
Flashing Red and Yellow = over temp
Flashing Green and Yellow = low voltage cut-off(battery)
Flashing Green OR Red = Speed control has not been calibrated and is not armed; or throttle sub-trim is not at 0.
Solid Green OR Red = should not happen when at neutral, indicates full throttle/reverse
Flashing Yellow = possible problem with controller (Mamba Max Pro indicates neutral and armed with C.H.E.A.T. turn off)
Solid Yellow = indicates neutral and armed (Mamba Max Pro indicates neutral and armed with C.H.E.A.T. turn on)
Flashing all colors = speed control is not receiving a valid signal from the receiver, usually indicates the receiver wire is plugged in backwards into the receiver; possible problem with controller or with throttle channel on receiver.
If you are applying throttle or reverse when NOT calibrating:
Flashing Green OR Red = indicates partial throttle (green) or reverse (red)
Solid Green OR Red = indicates full throttle (green) or reverse (red)
Solid Yellow = should never happen
If you are applying throttle or reverse WHEN calibrating:
Flashing Red and Yellow = should not happen when calibrating
Flashing Green and Yellow = should not happen when calibrating
Flashing Green OR Red while beeping = indicates speed control is looking for full throttle (green) or full throttle (red). If it continues for more than ~ 8 seconds, indicates speed control is seeing partial throttle (green) or reverse (red), increase endpoints on transmitter so speed control sees full throttle/reverse.
Solid Green OR Red = indicates full throttle (green) or reverse (red) has been read
Flashing Yellow = speed control is not seeing a valid neutral signal, check your transmitters throttle sub-trim is at zero, exponential is set to 0 or linear, and mixing is disabled.
Solid Yellow = indicates neutral has calibrated and is armed
Flashing all colors = speed control is not receiving a valid signal from the receiver. Usually indicates the receiver wire is plugged in backwards into the receiver; also happens when speed control has accepted a calibration setting (throttle, reverse or neutral) and flashes/chimes 4 times before moving to next calibration point; or problem with throttle channel on receiver.
Brushlesshobbies.com
DESC410
