The Turnigy 3XS features a large, easy to read back-lit LCD, a quick access jog wheel for function selection and programming, 15 model memory, steering wheel extension as standard and a host of programming features normally only found on expensive "high-end" radios.
The 3XS not only looks great, it feels great in your hands, which is what really counts when it comes to surface radios. The ergonomics have been very well thought out on this one making all the functions such as Steering/Throttle trims easily accessible while operating your model. No need to take your hands off of the wheel or throttle trigger to make adjustments on the go!
This radio system is compatible with and includes the HK3100 3CH FHSS receiver. This receiver is compact and lightweight allowing you to install it in just about any model's radio compartment.
Features:
• EPA adjustment
• Sub trim
• Dual rates
• Servo reversing
• Programmable steering curve
• Programmable throttle curve
• ABS (anti-lock braking)
• 15 model memory
• Programmable steering/throttle speed
• Throttle hold function
• Integrated timer
Specs:
Transmitter;
Channels: 3
RF Type: 2.4GHz FHSS
Weight: 350g (without batteries)
Power: 4 x AA batteries
Receiver;
Channels: 3
Operating Voltage: 4.5~5.5V <30mA
Dimensions: 33 x 19 x 12mm
Weight: 9g
Required:
4 x AA battery
http://www.hobbyking.com/hobbyking/s...io_System.html
[UPDATE] Took me just a while to find the OEM of this cool system. It's made by HiSky
(Last edited by ericmaxman : 8.22.12 at 4:48 am)
* Nothing to see *
