TrackStar performance now in comes in easy to select Combo package!
Using a Fast Silicon Labs MCU and high quality On-Semiconductor MOSFETs the TrackStar 18A ESC sets a new standard in high quality yet affordable car ESCs. With Intelligent MCU logic the TrackStar series ESCs allow extremely precise start up control and positioning feed back from the motor. Combined with the quality 4 pole motor this translates in to very smooth start up and acceleration and torque.
The Turnigy TrackStar 18A ESC also boasts a host of programing options not usually found in an ESC of this size and can be programmed with ease via the Turnigy TrackStar programing card (sold separately)
ESC Specification:
Cont. Current: 18A
Burst Current: 25A
Car Size: 1/18th
Battery: 2-3 Cell Lipo / 4-9 Cell Ni-XX
L-BEC: 5V / 1A Output
Motor Type: Sensorless Brushless
Size: 30 x 26.1 x 13.8mm
Weight: 26g (Including wires)
Motor Plugs: 3.5mm Bullet type
Battery Plug: Required
On/Off Switch: Yes
Reverse: Yes
Motor Specifications:
Turns: 10T
KV value: 6100KV
Poles: 4
Diameter: 21.5mm
Motor length: 37mm
Extend shaft diameter: 2mm
Length of extend shaft: 11±0.5mm
Weight: 60g
No loading @ 7.2V: 2.7A
Max current: 40A
Resistance (Ω): 0.021Ω
Battery range: 2~3s 7.4v~11.1v
Operation Temperature: 80°
Max Temperature 130°
Suitable car scale: 1/18
Suitable ESC: 25A
Thickness of lamination: 0.2X20mm
NOTE: We suggest reducing your gearing if running this motor on 3S.
10T / 6100 kv
12T / 5050 kv
14T / 4300 kv
(Last edited by theJANG : 8.31.12 at 12:23 pm)
* Nothing to see *
