Hey i don't think you can run lipos in that car,my step bro have the 1/16 brushed e revo and you can run them it will fry the electronics.I would get the parrallel connector so you can run two batteries at the same time for just longer run time.There is also the series connector so you can run 2 batteries an get a little longer run time but more speed.The only problem i have come across with the series for those motors,is that the brushes in the motor start to fall out witch means you get allot less life out of the motor(even know i believe they are only about $35.00).If you don't know what the parallel connector looks like from the series,you should Google images them so you know what you buying.They are about 6 or 7 $ each plus the extra battery that's around $ 25.00 so that's a pretty good cheap upgrade for either more speed or longer run time.Also well you aren't a kid like me with a tighter budget i wouldn't buy any upgrades.Just wait till it breaks so you dot waste you money on stuff.What happened to me was i got a very expensive 1/10 e revo brushless that i was saving for,for a while.Then i got some extra money and went to my local hobbies store and bought $150 in upgrades,that day i came home put them on and broke the chassis clean in half.I had no money to fix it for a while.But if you do break stuff i would definitely go with RPM they make very strong affordable. parts.
(Last edited by rcbuilder93 : 1.02.13 at 12:21 pm)
1/10 Traxxas summit
1/10 Slash 4x4 platinum LCG
1/16 E revo brushed
Jang usually says"You either have a summit or you don't" Well i sir have a summit"Traxxas forever
