slopokey said
What is the need for the axle upgrade unless your doing the Mamba Monster conversion or similar?I have the Mip shafts because I did some research.I did some trial and error on the stock shafts also can use say twisted like a pretzel.Back to my point they were necessary to have.I still run stock shafts in my Bandit with a Castle 5700kv geared as high as possible.Spend your money on some thing useful like better tires,servo,batteries or charger
The plastic yokes on the stock axles will eventually oval out even on 2s on high traction surfaces (ie street running and such) plus the axles will twist and not slide properly.
At $10 per side if you replace them 4 times then you're at the price of the Tekno's so it makes sense to upgrade to Tekno's once the included stock axles wear out. I simply just refuse to spend anymore money on plastic axles these days.
| Hyper 9e | Slash 4x4 STRC LCG | TLR 22T |
| Stampede | Stampede 4x4 |
| TT-01E Lightning | Lunchbox |
| Serpent 811T-Going Electric....Soon |
