JConcepts have introduced two new tires for 1/8th offroad, the Stackers and Black Jackets. The Stackers is a culmination of successful DNA from the highly popular Hybrids and Crowbars tire tread patterns which reveals a heavy center lug design which is supported at the lower base with extra rib features and tiny fillets which provide a heavy forward gripping force. Directional slashes cut into the tread soften the lugs to absorb bumps and also increase the lug flexibility to accommodate loose conditions. The Black Jackets, constructed from very small square pins, provide additional grip on loose conditions with a light amount of dust and debris across the surface. The tread spacing near the outside rows are slightly open allowing maximum flexibility to adhere to smooth and slick surfaces providing a reasonable flex contact patch. The crisp center bar construction provides a wall-like pattern of tread which provides additional forward bite and also resists some high-expansion wear associated with typical small pin tires.
Source: JConcepts [jconcepts.net]
News brought to you by...
01000010 01101001 01110100 01100101 00100000 01101101 01111001 00100000 01110011 01101000 01101001 01101110 01111001 00100000 01101101 01100101 01110100 01100001 01101100 00101110 00101110 00101110 00100000 01100001 01101110 01110100 01100101 01101110 01101110 01100001
