BillDeLong - 1.07.13, 12:16 pm Post #1: | Reply With Quote
Available in Red or Blue:
http://www.racers-edge.com/category_s/162.htm
Some parts are also compatible with OFNA's TS2 rebrand of the RE-Pro2.
RacersEdge said
The Racers Edge Traverse Ready To Run Offroad Truck combines good looks and great performance at an entry-level price. With the included electronics and radio package you cannot find a better deal. The Wizard Lipo Capable Electronic Speed Controller paired with the 3600kv finned can motor set the Traverse in action in a quick way, with high speeds right out of the box. The GLG20 Transmitter and GL1x receiver package offer the latest in interference free 2.4Ghz operation, so you never have to worry who else might be running another RC car in your area. Mega-Flex plastic components throughout the design offers the best mix of durability and performance. With a completely tunable suspension package, full ball bearings, adjustable turnbuckles and Constant Speed drive shaft assemblies you won’t be left in the dust by your competitors. Ready to race in the backyard or at the track! Available in two body styles, red & blue.
The Racers Edge Ready-to-Run 2wd Traverse Offroad Truck
  • SGS6 Metal Gear Servo - Speed and Torque With Durability in Mind
  • Metal Gear Fluid Filled Differential - Capable of Handling the Rigors of Brushless and Lipo Power Plus the Advantage of Tuning with Different Viscosity Diff Fluid to Suit Driving Conditions
  • Brushless Wizard ESC –7 Cell Nimh/2 Cell Lipo Capable with Lipo Cutoff –Easy Programming with Forward & Reverse. 3600kv Rated Brushless Motor with Finned Can Design for Cool Operation. Deans Ultra Plug Hardwired – PLUS- Standard Plug Adapter – The Ability to run Deans Wired or Standard “Tamiya” Wired Battery packs right out of the box.
  • Water Proof Electronics System - Receiver Chassis Box Protecting Vital Electronics from the Elements
  • Upgraded Front End Geometry - Revised Front Chassis Top and Bottom Plate for Improved Durability Across all Racers Edge 2wd Platforms
http://www.racers-edge.com/v/vspfile...rx-box-t&b.jpg
  • Mega-Flex Plastic Components Throughout for the Best Mix of Durability & Performance.
  • Completely Tunable Suspension System with Oil Filled Rebuildable Shocks & Polished Steel Adjustable Turnbuckles.
  • Constant Speed Drive Shaft Assemblies for Smooth Power Delivery. Red Anodized Aluminum Motor Plate, Front Brace & Servo Saver Set for Optimum Performance
  • GLG20 2.4GHz Transmitter with 3 Channel Receiver
  • Full Ball Bearings
Instruction Manual PDF
Exploded View
Features
  • · The Racers Edge Ready-to-Run 2wd Traverse Offroad Truck
    · GLG20 2.4GHz Transmitter with 3 Channel Receiver
    · Brushless Wizard ESC –7 Cell Nimh/2 Cell Lipo Capable with Lipo Cutoff –Easy Programming with Forward & Reverse.
    · 3600kv Rated Brushless Motor with Finned Can Design for Cool Operation
    · Two Pre-painted Lexan Body Styles Available
    · Mega-Flex Plastic Components Throughout for the Best Mix of Durability & Fun-Ability.
    · Completely Tunable Suspension System with Oil Filled Rebuildable Shocks
    · Red Anodized Aluminum Motor Plate, Front Brace & Servo Saver Set for Optimum Performance
    · Polished Steel Adjustable Turnbuckles
    · Full Ball Bearings
    · Deans Ultra Plug Hardwired – PLUS- Standard Plug Adapter – The Ability to run Deans Wired or Standard “Tamiya” Wired Battery packs right out of the box
theJANG - 1.07.13, 1:21 pm Post #2: | Reply With Quote
Also known as the Team C TC02T, design & OEM wise at least (but with most likely softer plastics).
TurboShadow - 1.07.13, 1:30 pm Post #3: | Reply With Quote
$199 RTR lipo ready and brushless? Looks like a steal! Anyone have any experience with the electronics this uses or the truck under a different name? ST's make good bashers, and this looks like alot of bang for your buck.
nitrogo25's Avatar
"I swear to drunk Ocifer!"
nitrogo25 - 1.07.13, 1:44 pm Post #4: | Reply With Quote
isnt magna flex used in the duratrax cars?
Dtx Evader Brushless (out of commission)
Hpi Blitz Brushless
Redcat Terremoto
DHK Hunter
pinoyboy22 - 1.07.13, 1:46 pm Post #5: | Reply With Quote
Oops didn't see Jang's post.
(Last edited by pinoyboy22 : 1.07.13 at 2:09 pm)
HPI Baja 5B SS/HPI WR8 Ken Block Rally/HPI Sprint 2 Flux/Kyosho Sandmaster/Tamiya TXT-1/Ofna DM1 Spec E/Caster Racing F8T truggy/Losi 8ight TE 2.0/Radiopost TS-401/Futaba 3PKS Fasst
Byodood - 1.07.13, 1:49 pm Post #6: | Reply With Quote
Thats a lot of car for 200 bucks, hell. I might pick me up one.
nitrogo25's Avatar
nitrogo25 - 1.07.13, 1:50 pm Post #7: | Reply With Quote
the compount of plastics they used because in my ext2's manual it said it uses magnaflex
Hpi Blitz Brushless
Redcat Terremoto
DHK Hunter
BillDeLong - 1.07.13, 1:55 pm Post #8: | Reply With Quote
Says Megaflex in the OP, sure hope its not the same plastic as Duratrax, that would be very bad if it were
theJANG - 1.07.13, 1:56 pm Post #9: | Reply With Quote
I believe that's just a made-up name, like Nutrium or Hydroplex.
BillDeLong - 1.07.13, 1:57 pm Post #10: | Reply With Quote
Unobtaniaplex
