ericmaxman's Avatar
ericmaxman - 1.29.13, 3:03 am Post #1: | Reply With Quote
The all new Turnigy GT-10X 1/10 Pan Car Kit is a high performance model loaded with features. The lightweight, slim-line design enables the GT-10X to be very agile and aggressive in the corners. From asphalt to carpet, this car can handle it all!
The GT-10X sports all of the features that you would expect from a high performance 1/10 Pan Car, such as a ball diff rear axle, lightweight carbon fiber chassis, fully adjustable front/rear suspension and rear side-links, open motor pod, adjustable front camber/castor and the list goes on!
A great feature of this chassis is the open motor pod design that makes installing, adjusting and swapping of brushless motors quick and easy. The motor mount is made of ultra-durable and lightweight 5mm CNC aluminum alloy. It's then anodized in a beautiful blue finish giving it that "hopped-up" look.
The GT-10X includes a servo mount that will accommodate most standard size servos, giving you a wide range of steering servo options. The battery tray is a perfect fit for our ROAR approved Turnigy nano-tech 1S 5000mAh hard case lipoly battery, and will suit most other 1S hardcase battery packs as well.
This car comes pre-built and almost ready to run, even the foam tires and wheels are pre-mounted. You will simply need to install your own brushless motor, ESC, steering servo and 2CH radio system (transmitter and receiver) to be ready to hit the track!
Features:
Lightweight slim-line design
High performance rear ball differential
Fully adjustable front/rear suspension including rear side links
Oil-filled aluminum bodied rear shock
Open motor pod design
3mm carbon fiber chassis construction
Pre-assembled chassis
Pre-painted/trimmed body shell included
Specs:
Length: 420mm
Width: 200mm
Height: 115mm
Tread: 170mm
Wheel base: 260mm
Battery tray size: 96x50mm
Chassis weight: 515g (w/no electronics)
Includes:
GT-10X pan car chassis
All required hardware
Requires:
2CH transmitter and receiver
3650 size brushless motor
Brushless ESC
Standard size steering servo (3KG torque or higher)
4000~5000mAh 1S lipoly battery (2S optional)
http://hobbyking.com/hobbyking/store...dProduct=29107
$69.99
* Nothing to see *
tj_7alberto's Avatar
"I am experienced now?!?"
tj_7alberto - 1.29.13, 6:12 am Post #2: | Reply With Quote
I know nothing about Pan cars (or even onroad in general) but I thought pan carsnwerent supposed to look so... Scale Haha
tamiyafier's Avatar
"eheheheheh"
tamiyafier - 1.29.13, 6:51 am Post #3: | Reply With Quote
*cough* F-1 *cough*
Pan cars are actually pretty scale looking, with the exception of the super aerodynamic race bodies. Tamiya really turned out a few stunners in the eighties and nineties.
"'You miss 100% of the shots you don't take.'- Wayne Gretzky"
-Michael Scott
thepiper92 - 1.29.13, 6:53 am Post #4: | Reply With Quote
I thought pans usually had the wedge shaped body. This is closer to a touring style.
tamiyafier's Avatar
"eheheheheh"
tamiyafier - 1.29.13, 6:55 am Post #5: | Reply With Quote
Is "pan car" defined by the chassis or the shell? I'm not quite sure of that one. The Tamiya F103GT is the same size as a 190mm TC, but uses the standard pan car chassis layout.
-Michael Scott
andersonwal's Avatar
andersonwal - 1.29.13, 6:57 am Post #6: | Reply With Quote
It's a 1/10 scale GT car. Pan cars are usually 1/12 scale. GT cars are based on the same design but longer and with somewhat more realistic bodies.
1% evil, 99% hot gas
thepiper92 - 1.29.13, 7:00 am Post #7: | Reply With Quote
Ah. Well it's a good looking body the comes with it.
tamiyafier's Avatar
"eheheheheh"
tamiyafier - 1.29.13, 7:06 am Post #8: | Reply With Quote
Thanks for clearing that up.
-Michael Scott
Greg - 1.29.13, 7:17 am Post #9: | Reply With Quote
I used to race 1/12 scale, would love to get back into it in 1/10 scale if there was only a track around here. This car looks sturdy like it can take a hit, and the front end looks like it might be able to accept the Team Associated type front suspension.
cartix's Avatar
cartix - 1.29.13, 7:24 am Post #10: | Reply With Quote
Pan cars are both 1/10 & 1/12 scale. Bolink, Associated etc all had kits in both classes back in the 90's. 1/10 oval uses pan car chassis also, with the battery offset on the left side of the chassis. GT pan cars are now very popular.
$70, body included, looks promising .
