Mrfishingbig's Avatar
Mrfishingbig - 8.09.13, 10:39 am Post #1: | Reply With Quote
I want to bash with more power but the lipo I got doesn't fit so what 2s lipo do you use.
redneckguy's Avatar
"UnderCover ;)"
redneckguy - 8.09.13, 11:07 am Post #2: | Reply With Quote
what lipo did you get? usually high mah batteries tend to be a little bigger..
Mrfishingbig - 8.09.13, 12:28 pm Post #3: | Reply With Quote
It was a 5000mah soft case turnigy battery
Trouble Maker's Avatar
"Very Experienced User"
Trouble Maker - 8.09.13, 4:30 pm Post #4: | Reply With Quote
DONT USE SOFT SHELL IN LAND VEHICLES! if a rock gets stuck in your battery compartment it can puncture your cells! the Venom 4100mAh 25C 40C burst is really good and really cheap, I had enough left over money to by an Onyx 235 charger!
I CAN'T BELIEVE IT'S NOT BUTTER!!!!!!!!!!!!!!!!!!!!!
Mrfishingbig - 8.09.13, 7:22 pm Post #5: | Reply With Quote
But will it fit in the raider
bjb's Avatar
bjb - 8.10.13, 9:10 am Post #6: | Reply With Quote
I got some 5000mah lipos from Value Hobby that work well. They are slightly thick for the battery box, but they still fit. Arrma says a battery 25mm thick will fit, but that seems to be pushing it as far as I am concerned. The ones I got from Value Hobby are 23mm thick and are pretty tight. I got this one, but the majority of the 2s lipo packs they sell are 23mm or thinner.
bjb's Avatar
bjb - 8.10.13, 9:13 am Post #7: | Reply With Quote
One other thing to add about lipos on the Arrma buggies. I soldered bullet connectors on to the ESC, and I plug the bullets directly into my battery. I don't use the battery lead that came with the battery. I think it works better than using a plug like a Deans, because the wires take up less space in the already really confined area.
adubs117 - 8.10.13, 9:20 pm Post #8: | Reply With Quote
My brother has an arrma fury and uses the Duratrax Onyx 2S 7.4V 5000mAh 35C Hard Case Deans. You can find it on tower hobbies and the dimensions of the lipo are posted in case you want to search for a cheaper battery.
Mrfishingbig - 8.11.13, 7:57 am Post #9: | Reply With Quote
OK thanks
Trouble Maker - 8.22.13, 3:40 pm Post #10: | Reply With Quote
yes
