URC Newsbot's Avatar
"011101010111
001001100011
URC Newsbot - 2.04.14, 1:40 am Post #1: | Reply With Quote
Seen for the first time at the recent Nuremberg Toyfair, Spektrum soon have their new S9010 and S9020 large-scale servos available. Developed by Paul Beard, who brought the 2.4GHz technology to RC, the servos will feature a patent-pending back EMF technology that does away with fading issues and weak holding power while dynamic breaking technology assures the vehicle maintains the heading demanded thanks to the servo’s high level of holding power. An improved integrator design virtually eliminates the crowbar effect while keeping the servo temperatures low. Using back EMF technology, position lock exponentially improves the servos ability to keep its position while greatly increasing holding power. The servos are currently in development and will become available in the near future.
Features
– Improved integrator design eliminates crowbar effect and reduces heat build-up
– Socket-head cap screws
– HV for use with 2-cell Li-Po’s
– Waterproof
– Steering and throttle options available
– Removable, hi-strength servo lead
– Low profile standard 1/5-scale size
– Hardened steel gears
Source: Horizon Hobby [horizonhobby.com]
News brought to you by...
01000010 01101001 01110100 01100101 00100000 01101101 01111001 00100000 01110011 01101000 01101001 01101110 01111001 00100000 01101101 01100101 01110100 01100001 01101100 00101110 00101110 00101110 00100000 01100001 01101110 01110100 01100101 01101110 01101110 01100001
Streethawk's Avatar
Streethawk - 2.07.14, 6:36 am Post #2: | Reply With Quote
I wonder if we'll see these in the 5T RTR ad the stock servos in it are a joke, mine went out when I unbowed it in the store, with the manager holding the radio while we set the end point. 20 seconds, almost no use, throttle servo was on fire. britons protection manchester
EXO - 2.07.14, 8:10 am Post #3: | Reply With Quote
More then likely the end points were not set right if they lasted that short of a time. A lot of guys running the stock servos still in there 5ives.Still not the best servos by any means but certainly not the worst. Would be curios to see how these new spectrum servos work out for longevity. So far Hitec is leading the pack for the 5ive.
Streethawk's Avatar
Streethawk - 2.07.14, 8:19 am Post #4: | Reply With Quote
They weren't, but in setting them we weren't straining the servo much, it was never on fully for more than a couple of seconds at a time over the 20 second we were doing it. Any servo should last longer than that when loaded.
EXO - 2.07.14, 8:36 am Post #5: | Reply With Quote
Not really. Any an all servos will burn up really quick when its fighting. What servos are you running now?
Streethawk's Avatar
Streethawk - 2.07.14, 8:40 am Post #6: | Reply With Quote
The throttle servo was known for it, that's why I did it in the store and the manager, a The sponsored driver, was holding the radio.
I replaced it with a Savox, at cost price ;-) another part of my plan, I knew if it went out before leaving the store they'd offer me a better servo at cost, as I knew they didn't have the stock servo in... Er... Stock.
Streethawk's Avatar
Streethawk - 2.07.14, 8:40 am Post #7: | Reply With Quote
*TLR Sponsored
EXO - 2.07.14, 8:55 am Post #8: | Reply With Quote
So it was just the throttle servo that burned up. Thats right the older version 5ives problems with those. They come with a much better one now. Steering servo is still the same rebadged Savox though.
Streethawk's Avatar
Streethawk - 2.07.14, 9:02 am Post #9: | Reply With Quote
I ended up putting the high spec Savox I got (forgot the number) on the steering and the original steering servo on the throttle, worked well.
EXO - 2.07.14, 10:10 am Post #10: | Reply With Quote
More then likely a Saxox 236. That's what the stock steering servo is just rebranded by losi.
