drw814's Avatar
"Monster truck madness"
drw814 - 3.29.14, 2:01 pm Post #51: | Reply With Quote
I sold a couple things, and bought this from someone else there. I need a pull start to get it running though.
Gonna run it nitro for a quart or two, then convert it to electric. I have been looking for an xxl for a while, and I'm stocked I finally found/purchased one.
Summit Kawasaki / Brushless erevo / Brushed erevo / MERV / Mini 8ight / Vaterra kemora x2 / Bandit xl5 / Vaterra ascender / Sprint 2 / Rs4 sport 3 / Slash xl5 / Slash 4x4 / Tmaxx 2.5
Ocdcbr's Avatar
"It's only an opinion..."
Ocdcbr - 3.29.14, 2:06 pm Post #52: | Reply With Quote
Garradmiller said
Okay I can tell in the pictures it has metal diff cases but silver. I've seen a few styles.
its not the outer case that i mean...its within that, the plastic case that actually houses the gears. stock is plastic, hd is also plastic i think but with metal inserts where it counts....
RC FAN!
MUGEN MBX6 x 2nitro,1 Eco racers, Hpi Baja
TRAXXAS XMAXX!!yup....its good!
Check my Utube!!:Rc Maxx UK
Ocdcbr's Avatar
Ocdcbr - 3.29.14, 2:07 pm Post #53: | Reply With Quote
Does it not have the spin start?
RC FAN!
Garradmiller's Avatar
Garradmiller - 3.29.14, 2:08 pm Post #54: | Reply With Quote
Gotcha makes sense
drw814's Avatar
drw814 - 3.29.14, 2:29 pm Post #55: | Reply With Quote
Didn't come with it. Looks like there is a pullstart there, but the handle you pull on is gone.
Ocdcbr's Avatar
Ocdcbr - 3.29.14, 2:56 pm Post #56: | Reply With Quote
Fair enough. Looks like the motor that ce w my lst2.... Maybe it's not. Either way. Enjoy!
RC FAN!
drw814's Avatar
drw814 - 3.29.14, 3:36 pm Post #57: | Reply With Quote
How do you guys feel about possibly putting this motor in the lst for a conversion?
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXAGXB
Reason I ask is because I already have one and wouldn't have to buy another motor.
Ocdcbr's Avatar
Ocdcbr - 3.29.14, 3:55 pm Post #58: | Reply With Quote
I had the ripper 2000kv in mine on 6s briefly and a 1900 kv turnigy on 4s Both seemed ok to me. Several more experienced users thought that a lower kv on a higher cell would be better. After advice I went for the leopard 1480kv 92mm motor that I now run on 6s. That's what was in that vid I posted up.
No doubt that motor would b ok on 4s if u geared it right and monitored temps. ( the usual answer I guess) jumpit might chime in here as he's had a 2350 from what I remember and he's got a e lst xxl too....
RC FAN!
drw814's Avatar
drw814 - 3.29.14, 4:59 pm Post #59: | Reply With Quote
I know there are better choices, but I figured I would ask since I wouldn't have to buy a new motor.
If this motor runs too hot, I will probably get a leopard motor around 2000kv. I normally only run on 4s.
drw814's Avatar
drw814 - 3.29.14, 9:07 pm Post #60: | Reply With Quote
Also, for anyone wanting to do a 17mm hex mod, I had great success with my previous LST. I just slightly drilled out a set of traxxas 17mm hexes (like on the erevo and summit) to accommodate the LSTs lager axles. Used the stock traxxas pins to put them on the losi axles. Worked great, no rubbing, no washers/shims. May do it to this one as well if/when I want to switch to 17mm.
