Valkyrie? Nah, I wouldn't even pretend this is trying to be an "Ultimate" project.
Step 2: Prep the servo deck
For this buggy, the servo deck needs to be cut to remove the throttle servo mount and make more room. I first cut according to the manual's recommendation (as shown in the photos), but once I mocked up where the battery trays would be, I found that I needed to remove the transponder mount and slice about 1/8" of material off the outside edge of the plate for clearance.
Step 3: Mount the battery trays
I forgot to take pics of this step, but it was pretty straightforward. I had to drill holes through the stone guards for the mounts and also trim down a couple of the stone guard mounting screw posts from the top side to allow the trays to sit low and secure. Some installs will require drilling through the aluminum chassis to mount one of the battery tray.
Step 4: Prep the motor
Novak really did an interesting thing here, supplying a heat sink that works as a very secure, clamping mount. To install it, you need to remove the endbell, slide off the outer motor sleeve (a laborious process as it fit very, very snugly), apply the meager included dab of heat transfer paste (included q-tip NOT recommended as it is too absorbant), and then slide on the new 'sink before re-securing the endbell and tightening two clamping screws. Care needs to be given to ensure that you're orienting the motor terminals correctly, and lining up all screws and especially the endbell.
Step 5: Mount the motor!
This was a piece of cake. There's a 3mm hard-anodized metal adapter plate included that screws directly onto the bottom of the heat sink/mount (use threadlock!), and then you use your original nitro motor mount screws in their original locations to secure the adapter plate. Kits for some buggies require alternate hardware (included, and noted in the instructions).
Next up, it'll be time to get the electronics situated.
